Difference between the two monitors
Go to solution Solved by BobVonBob,
The cheap one has a lower resolution, 1440x900 instead of 1920x1080.
What kind of features am i getting from the more expensive monitor over the cheaper one? I'll be using it for gaming.
And I'll not be setting up multi monitor setup.
Expensive one: http://ucc-bd.com/viewsonic-monitor-va2256-h-21-5-2623.html
Cheaper one: http://ucc-bd.com/viewsonic-20-19-5-viewable-led-monitor-with-superclearr-ips-technology.html
Price difference is $30, so if i take the cheaper one. I could invest on a better keyboard.
1. Frequency difference?
2. Image clarity?
3. Both seem to be IPS display but ome seems to be LCD and the other LED.
Note: not really bothered by the response time as within ~15ms is fine (for me)
https://linustechtips.com/topic/1039162-difference-between-the-two-monitors/
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
Definitely get the more expensive one! dont want to be on 1440*900 in this day and age
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
