Hey!
My build is almost complete, missing a CPU cooler (and some fans).
I am not going to do heavy overclocking and I do care about aesthetics. Therefore, I am leaning towards AIO water cooling for the CPU.
RGB is more than welcome - since I am getting probably another rear RGB fan.
Current build is
CPU: Intel - Core i7-9700K 3.6 GHz 8-Core Processor  ($418.99 @ Amazon)
Motherboard: Gigabyte - Z390 AORUS PRO ATX LGA1151 Motherboard  ($179.99 @ Amazon)
Memory: G.Skill - Trident Z RGB 16 GB (2 x 8 GB) DDR4-3200 Memory  ($140.98 @ Newegg)
Storage: Crucial - MX500 1 TB 2.5" Solid State Drive  ($134.85 @ OutletPC)
Video Card: EVGA - GeForce RTX 2080 8 GB Black Video Card  ($729.99 @ B&H)
Case: Fractal Design - Meshify C TG ATX Mid Tower Case  ($99.98 @ Newegg)
Power Supply: Corsair - RMx (2018) 650 W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.99 @ Newegg)
Total: $1784.77
Generated by PCPartPicker 2019-02-27 09:14 EST-0500
What would you recommend?
Thanks a lot !!
https://linustechtips.com/topic/1038814-choosing-a-cpu-cooler/
Well if OP wants RGB, I hear the cooler master AIOs are pretty cheap.
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
https://linustechtips.com/topic/1038814-choosing-a-cpu-cooler/#findComment-12349179
