In my brand new build, I have a masterbox q300l with one fan on the back side that was included. I have an rx 580 and a ryzen 5 2600. According to Speccy, the GPU and motherboard will stay in mid to high 30 C degrees. But when I am just internet browsing the cpu temp is high 80s. So should I get a new fan cooler (I am using stock wraith spire w/ stock thermal paste) or add more fans for the top of the case (or front)?
https://linustechtips.com/topic/1038346-cpu-air-cooler/
Is your CPU actually at 100%? Are other programs also confirming this temperature? What is your ambient temperature (the temperature in the room you're in).
Coincidentally there was a Ryzen 5 2600 + stock cooler question a bit before and I looked up a review for temperatures to find a normal temperature (when at full load).
Quote from the Techspot review:
Quote
Now let’s talk temperatures. For testing we maintained an ambient temperature of 21 - 22 degrees and the Asus ROG Crosshair VII Hero along with the Ryzen 5 2600 and its box cooler were placed in our Corsair Crystal 570X ATX case. Under these conditions the Wraith Stealth kept the R5 2600 at 74 degrees in our Blender stress test.
https://www.techspot.com/review/1614-ryzen-2600/page5.html
The 570X is a pretty good case with 3 120MM intakes (in its default config, which I assume they were using since there is no mention otherwise).
If your room is 10 degrees C higher than their room, it's not weird if your CPU temp is also 10 degrees C higher for example. Having less airflow may increase temps too.
So really, it's important to verify what I asked above and from there it can be discussed further if high 80's C temps are expected or not.
Just to preface; max temps of close to 90 degrees C are not weird if, your room is warmer, you have less airflow in the case and the CPU is working at 100%.
https://linustechtips.com/topic/1038346-cpu-air-cooler/#findComment-12340281
Use Ryzen Master to monitor the temps, not Speccy. Ryzen Master does it the best. And then HWMonitor, OpenHardwareMonitor and HWinfo64.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1038346-cpu-air-cooler/#findComment-12340404
