GPU power cable LED
Go to solution Solved by Guest,
Yes
There are some that are even on when the computer is turned off. But I'm sure you can change this in the Aura driver too or am I wrong?
What is your PSU some have eco modes that really shut down everything at shut down.
I remember like 10 years ago someone at a LAN party had a full glass case and the lights were glowing even though the computer was also shut down... never mind lol
https://linustechtips.com/topic/1038064-gpu-power-cable-led/#findComment-12337883
