Hey guys,
I am out of my mind with the issue I am experiencing here. Heres what I have:
AMD Ryzen 7 2700X
Asus ROG Crosshair VII HERO (with latest BIOS)
Corsair Vengence RGB PRO (2x8GB, DDR4, 3000MHz C15)
Every time I try to overclock the RAM to its advertised speed (3000MHz), the board's Q-Code display shows the code "C8", which doesn't exist in my model's Manual... Then goes on to display "Memory Settings reset because of failure to boot".
I've reflashed the BIOS about 3 times, changed memory slots. The works.
I've seen other builds with the same set up of parts, and I bought all of this in August of 2018, and I am just trying XMP/DOCP now. Any ideas?
https://linustechtips.com/topic/1037573-xmp-docp-overclock-issues/
Run it with D.O.C.P. but change it to CL16 then try and see if it will post. You can also try more dram voltage or upping the SOC voltage slightly (.01-.05v)
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
Sadly none of the setting changes worked. I dont know why it won't accept anything higher. No matter what I do.
