I build my first gaming rig 2 years ago and was new to the PC gaming world. I built a bottlenecking system having an AMD A6 6400K paired with a GTX 1050ti  And has a 500W Psu. (Yeah, i was a noob). So, recently I have decided to upgrade its CPU. So should I go with an AMD Rysen 3 1200 or a 1300X or an Intel Equivalent? Any sort of help is appreciated. (PS: I'm on a tight budget). Budget: For CPU alone $90 Max For Cpu, mobo, ram Total: Approx $220
Edited by AryanSawant
https://linustechtips.com/topic/1037374-serious-bottlenecking-issue-need-help/
Give us your budget in USD pls
The Athlon 200GE will offer an easy upgrade path in the furure to the Ryzen processors because it uses the same socket.
A good mobo is the asrock pro4.
Gigabyte B450M DS3H is cheaper and mATX but won't support anything much better than Ryzen 3 2200G.
Ok Thanks!
Something like this, you can overclock the CPU and RAM a little bit more pretty easily.
(◣_◢) Ryzen 5 3600,   Aorus X370 K7,   XPG 16GB 3200,   Gigabyte 2070 Windforce Corsair RM650x,   LG 32GK650F-B 31.5" 144Hz QHD FreeSync VA,   Kingston 120GB SSD,   Samsung 1TB 860 QVO,   2TB HDD,   Fractal Design Meshify C,   Corsair K63 Wireless,   Corsair Gaming M65 PRO,   Audio Technica ATH M50x,   Windows 10 ProCorsair H100x 240mm.  (◣_◢)
(◣_◢) Ryzen 5 1600,   Noctua NH-L12S,   Gigabyte GTX 1060 6G,   ASUS Prime B350 Plus,   HyperX Fury 8GB DDR4 (2666MHz - 1.3v),   SilverStone ET550-B,   Kingston 120GB SSD 2TB HDD,   Cougar MX330,   Windows 10 Pro.  (◣_◢)
Seems good to me, Thanks for the help!
