Hi ,im looking to replace my noisy psu with a budget (less noise possible) one  i was about to get a masterwatt then i saw some decen amout ppl saying that it makes coil whine under heavy load so im really scared coz  im looking for a quiet one and there is not much choice here,  so the only 3  quiet  budget  power supplies i have to choose from are the : masterwatt 550//crosair vs550 // thermaltake smart rgb 500w or 600w .  i'm using an i5 7500/ gtx 1060 3gb and 12gb  of ram . i really appreciate any help
https://linustechtips.com/topic/1037229-help-choosing-psu/
26 minutes ago, Hip said:
What is your budget?
I would buy nothing below Gold PSU. I can recommend Seasonic Focus Plus Gold 550
well the budget is not that tight but the choice is very limited i wanted to get a be quiet psu but the  lowest powerful one is 850w and it's expensive  i looked just now  for a seasonic and the  only one available *probably* is a 750w one and it's bit expensive ill check if they still have one in stock , but maybe help me choose from the  3 ones   that probably i'll end up getting one of them ://
https://linustechtips.com/topic/1037229-help-choosing-psu/#findComment-12330973
Tbh I looked them all up and I'm not a fan of any of these.
None have modular cable management which is a no for me. You will possibly end up by having some cables hanging around your case which you won't need.
Efficiency is also not great in these. I'd rather get something with Gold certification as I said before.
If you want to choose between those I would take Thermaltake only because I had good experience with the "Berlin" PSU years ago, but only because of that.
https://linustechtips.com/topic/1037229-help-choosing-psu/#findComment-12331082
All aren't great but the Master Watt might be the best of the bunch...
Any other options??
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/1037229-help-choosing-psu/#findComment-12332050
Can you give us a link to the stores you are choosing from? Would be easier that way.
How can you say that without knowing what models are available? Or do you mean the 3 ones listed in original post?
Ex-EX build: Liquidfy C+... R.I.P.
Ex-build:
Meshify C – sold
Ryzen 5 1600x @4.0 GHz/1.4V – sold
Gigabyte X370 Aorus Gaming K7 – sold
Corsair Vengeance LPX 2x8 GB @3200 Mhz – sold
Alpenfoehn Brocken 3 Black Edition – it's somewhere
Sapphire Vega 56 Pulse – ded
Intel SSD 660p 1TB – sold
be Quiet! Straight Power 11 750w – sold
https://linustechtips.com/topic/1037229-help-choosing-psu/#findComment-12332195
i  looked at all the stores here  there is  more models but  those are the only ones with silent fans and not so expensive, and ye  i guess he is talking about the 3 models i listed there
https://linustechtips.com/topic/1037229-help-choosing-psu/#findComment-12332291
I looked the 3 up that he mentioned.
https://linustechtips.com/topic/1037229-help-choosing-psu/#findComment-12332333
Well, the only thing I can suggest is to look up available models at https://www.cybenetics.com/index.php?option=power-supplies. You can find fan RPM/noise level at certain loads
Ex-build:
Meshify C – sold
https://linustechtips.com/topic/1037229-help-choosing-psu/#findComment-12332538
15 hours ago, OrionFOTL said:
Well, we sure as hell can't recommend you anything since we still don't have any idea what's available or any links to stores.
i got an rm650i today  i plugged it in into the wall to do the fan test before putting it in my pc but nothing happening the fan not moving at all should i plug it in the motherboard or smth before doing the fan test ?
https://linustechtips.com/topic/1037229-help-choosing-psu/#findComment-12339166
