It might be "logic" to you what you want, but to mess up someones code is pretty hard.
The info you gave me, just do a reverse for loop, the first will be the last etc.
let i = array.length,
array = [xy];
for(;i == 0;i-- ){
  console.log(array[i]);
If you want a better answer, start posting your code here. If you're woried about someone stealing your stuff, I have bigger projects on my github where people can download it..
AMD FX8320 | GTX660 | 4x4GB DDR3 | LG ZR2740W
Logitech Wireless Pro  | Logitech G413 | Nuforce uDAC5  | AKG K612
https://linustechtips.com/topic/1037144-js-basic-issue/#findComment-12332903
Im assuming you wanted to swap two html elements in the DOM...
<!DOCTYPE html>
<html lang="en">
  <head>
    <meta charset="UTF-8" />
    <meta name="viewport" content="width=device-width, initial-scale=1.0" />
    <meta http-equiv="X-UA-Compatible" content="ie=edge" />
    <style>
      h3 {
        margin-top: 0px;
        margin-bottom: 0px;
    </style>
    <title>Swapping Two HTML Elements</title>
  </head>
  <body>
    <h3>0</h3>
    <h3>1</h3>
    <h3>2</h3>
    <h3>3</h3>
    <h3>4</h3>
    <h3>5</h3>
    <h3>6</h3>
    <h3>7</h3>
    <h3>8</h3>
    <h3>9</h3>
    <button id="button">Click</button>
    <script>
      // https://linustechtips.com/main/topic/1037144-js-basic-issue/
      // https://stackoverflow.com/questions/9732624/how-to-swap-dom-child-nodes-in-javascript
      button.addEventListener("click", function() {
        let headers = document.querySelectorAll("h3");
        headers[9].parentNode.insertBefore(headers[9], headers[0]);
    </script>
  </body>
</html>
https://codesandbox.io/s/myqz0w1mqp
If this isnt what you wanted then please edit the codesandbox to reflect you problem so we can help you better.
https://linustechtips.com/topic/1037144-js-basic-issue/#findComment-12334575
