You could just get 2 AIO's...be cheaper...Because if you did custom loop I'd highly recommend res<rad (240 atleast)<cpu<rad<cpu<res. But if your wanting to add more components in the future then custom loop is the way to go. Those Quick connect AIO's are expensive just as much as a custom loop. So there are solutions out there.
My Rig: CPU: i9-9900k (5Ghz), Ram: 32gigs 3600mhz DDR4 CL16, MOBO: Gigabyte Aorus z390 Ultra, HDD: Samsung 970 Evo 500gig x2, Samsung 850 evo 250 gig, 2 TB Baracuda 7200 rpm,6tb WD Black 7200rpm, 4TB NAS, GPU: Gigabyte Aorus 3090 Master
https://linustechtips.com/topic/1036964-multi-cpu-aio/#findComment-12328843
Yeah, 2 AIOs will definitely be cheaper. I did a quick mock up and doing a regular custom loop would be less than using a quick disconnect system, but a qdc is less likely to have leak issues if you're too worried to do a custom loop
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/1036964-multi-cpu-aio/#findComment-12328896
I suppose they assume that if you need two CPUs, you're savvy enough to make a custom loop.
As was mentioned, would be cheaper to buy two aios.
I once gave Luke and Linus pizza.
Proud member of the ITX club.
**SCRAPYARD WARS!!!!**
#BringBackLuke
https://linustechtips.com/topic/1036964-multi-cpu-aio/#findComment-12328921
