Look at r/cableporn to get some ideas
https://linustechtips.com/topic/1036868-it-cable-management/#findComment-12328086
You may already know this but If in the US avoid using velcro on any cables in areas that have or might have any patients in the area. I have seen Joint Commission inspections that ended with all velcro had to be removed  due to it is a surface that cannot be cleaned.
https://linustechtips.com/topic/1036868-it-cable-management/#findComment-12328233
