Is there any way to o run two OS in one system?
Solved by FlappyBoobs,
2 minutes ago, SGBudgetGamer said:I think she meant the first one, she wants both Windows 10 and Apple OS
If it's an Apple device that just needs to run a few windows apps then I would recommend parallels. You can then choose to run either in "full screen mode" where it feels like you are running windows on your mac or in "Coherence mode" which allows you to simply run the windows apps as if they were native to the mac. One of the big benefits of parallels is that it allows you to choose which OS to run, so you've got multiple Linux distros available as well as windows 10...it's also an automatic installation, just install parallels and then follow the on screen instructions to download and install windows 10.
