Hello.
First post here.
I have been getting some weird FPS drop problems in CSGO.
Happens on certain maps such as De_Dust2 on short and A site etc. The FPS drops to around 60-100.
My PC specs are as follows:
i7-8700k
GTX 1080
16GB RAM @ 3200Mhz
500GB Samsung 970EVO
Have tried:
Reinstalling game.
Reinstalling display drivers.
https://linustechtips.com/topic/1036483-csgo-fps-drop-problem/
55 minutes ago, uniQQ said:
Hello.
First post here.
i7-8700k
GTX 1080
16GB RAM @ 3200Mhz
Have tried:
Reinstalling game.
I would personally run DDU "Display Driver Uninstaller" in safe mode then clean and restart and come into normal mode and install the latest WHQL driver and let us know how CS:GO performs then.  Depending on resolution you should be at 200fps at all times.  You have a solid system I think its just a software or windows or CS:GO issue.  Your hardware can breeze through that game.  Also note CS:GO is very CPU dependent and not optimized properly for todays GPU's and what not.  What frame rate do you get and what does it drop down to ?
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1036483-csgo-fps-drop-problem/#findComment-12324377
I get around 250-300 but it drops to 90-120 at times.
I have removed CAM software from running tasks etc (as some people reported that NZXT CAM causes fps problems)
I have iCue, Thundermaster, Aura, and probs Logitech gaming software running (but all on default settings) - no GPU overclocking etc.
See screenshots
https://linustechtips.com/topic/1036483-csgo-fps-drop-problem/#findComment-12327708
