Power Supply Size
By
M1KU
in Power Supplies
in Power Supplies
Solved by mariushm,
Your computer may have a proprietary power supply, which would make it difficult if not impossible to replace the power supply with another one.
Determine first if your power supply is properietary, or SFX, or ATX.
If yours is the slim kind with a kind of square-ish power supply, then most likely that's a proprietary power supply.
Vibora ·
Posted in New Builds and Planning3 -
4
3
Doctah ·
Posted in Peripherals2 -
6
michaelb198 ·
errorcode123_dindin1 ·
Posted in Graphics Cards5 -
Packhunter ·
Posted in Graphics Cards6
