I just bought my first GPU rx570 and the first time I plug it in work fine (kinda) my PC did recognize but when I open a game (apex) I try to adjust video settings and crash I got a full green screen, then restart the PC and won't start so I have to restore my PC.
Already reinstall the drivers (all and drivers) and still won't work, I try update from device manager and also get green screen but this time I couldn't restore my PC so I install a clean windows 10
Know my PC won't recognize my GPU, if I install latest driver it says "Error 1603" so I try install other drivers and install perfectly, but still won't recognize.
I have try a lot of things and nothing work.
Ryzen 3 2200g
Gygabite b350 dh3s
8 GB ram
Evga 450w
Help pls.
I hope you can understand me, English isn't my first language.
Thanks.
https://linustechtips.com/topic/1036386-problem-with-rx570/
Ryzen 3 2200g
Gygabite b350 dh3s
8 GB ram
Evga 450w
Help pls.
Thanks.
Welcome to Red Hell.  Try a different PCIe slot and set your BIOS to defaults and let us know.  You may need to run DDU "Display Driver Uninstaller" in safe mode and that may work as well.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1036386-problem-with-rx570/#findComment-12323521
Already did DDU and didn't work, I will try another PCIe slot I hope it works :(
thanks
https://linustechtips.com/topic/1036386-problem-with-rx570/#findComment-12323597
thanks
Thank you for following my steps to solve this.  I really hope the PCIe slot is busted.  Let us know!  cross your fingers my friend.
https://linustechtips.com/topic/1036386-problem-with-rx570/#findComment-12323605
450 BT and I dont have another psu.
You have a Friend that could lend you a PSU??
It might be that the Transient of the GPU is something your cheap PSU can't deal with.
Random reboots are a sign of bad PSU/PSU Problem.
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/1036386-problem-with-rx570/#findComment-12325068
I dont have but I tried get one. thanks.
https://linustechtips.com/topic/1036386-problem-with-rx570/#findComment-12325072
Yeah, that's the only thing you can do right now.
You can go to Gaming -> Global Settings -> Global Wattman and go to power Limit (%) and move the slider to the hard left. That might fix it temporarily until you get a new, good quality PSU.
Where do you live?
What PSU are available??
https://linustechtips.com/topic/1036386-problem-with-rx570/#findComment-12325099
Where do you live?
Mexico
A lot, I see what I could do
Thanks.
https://linustechtips.com/topic/1036386-problem-with-rx570/#findComment-12325794
