Thinking of my first build.
Heres the specs I am planning
CPU:       Ryzen 5 2400 G
MOBO:    Asus Prime A320M-K
RAM:       16GB Vengeance RGB 2666Mhz DDR4
GPU:        MSI Radeon RX 570 8GB Armor OC
COOLER: Gamdias hione All-In-One CPU liquid Cooler (120MM)
CASE:      Coolermaster Masterbox Lite
M.2:          ADATA 256GB SSD (For OS)
SSD:        Kingston 960 GB SATA SSD (for programs and games)
HDD:        (2x4TB) Seagate Baracuda SATA HDD 4TB (fo movies, music and so on)
FANS:      2x Gamdias RGB 120MM case fans
SCARD:   ASUS Xonar PCI-e 5.1 gaming soundcard.
Build will be used for 1080P gaming and workstation use. I will have 2 or 3 monitors not yet decided. 5.1 channels sound system, Headset and so on.
I don't need or can afford 4k monitors so not really necessary. But 60+ FPS 1080P gaming would be nice
Games: GTA 5, Saints Row, Crysis, Left 4 Dead, Sims 4, Planet Coaster, CS go and such.
Workstation: Day job as CAD designer house plan drawing and so on. Also 3D renders of houses.
Cotent Creation: light photoshop and MAGIX Music maker and such.
Advice on build improvements and advice, Where I might have gone wrong. and can improve performance without upping the budget..
https://linustechtips.com/topic/1035792-some-build-advice/
14 minutes ago, Charlie23 said:
CPU:       Ryzen 5 2400 G
step up to a 2600 if possible
bad, b450(m) pro4 availible?
is okay, 3000+ is recommended tho
cheap cooler, get a different card
no need, stock cooler is good enough on ryzen
from my experience bad airflow
why? which?
which?
why?
why?
https://linustechtips.com/topic/1035792-some-build-advice/#findComment-12318191
why? which?
which?
why?
why?
Okay will check on most of that.
I have 3 storage drives because that Mobo supports M.2 so i can have a OS SSD M.2, a SSD for games and programs and HDD for movies and such.
Will scratch the AIO Cooler thats a big pricecut.
GPU: what is the problem there? Is that a bad card?
Soundcrad for speaker system, but have been told it is not needed.
It is also to be know i will not overclock anything,
https://linustechtips.com/topic/1035792-some-build-advice/#findComment-12319144
just for your info: m.2 is a formfactor, nvme is the faster one. that should be able to do on the b450(m) pro4
with the money you gained, get a 2600
gpu: yes, worse cooler than most cards
soundcard will not be needed, and the money gained can be invested to make that 570 a 580 for example
then I would still highly recommend a b450 board over a a320
https://linustechtips.com/topic/1035792-some-build-advice/#findComment-12319158
Yeah I know sorry about that just from work and a bit tired. Yes NVME m.2 SSd. for the OS.
So the 580 with 8GB vram then? That 570 had 8gb vram too.
I will check out the other mobo. it is double the price but a quick read it seams to support the same drives, cpu and so on. But mst importantly the one I found has RGB (that's a huge performance boost). You als said faster RAM? how will that help??
https://linustechtips.com/topic/1035792-some-build-advice/#findComment-12319261
ah okay... i would suggest looking around for the crucial p1, they seem to be pretty cheap
yes, it's a nice gain imo
you want rgb? the pro4 doesn't have any on it, but it does have a couple rgb headers (iirc)
vrms is what in the end counts on the mobo, so it's safe to let me check it
ryzen highly benefits from higher speed ram, the difference between 2400 and 3000 can be 20 fps sometimes
https://linustechtips.com/topic/1035792-some-build-advice/#findComment-12319267
The P1 is double the size but slower in read and write:
The P1
https://www.evetech.co.za/crucial-p1-500gb-nvme-ssd/best-deal/5279.aspx?gclid=CjwKCAiAkrTjBRAoEiwAXpf9CeocaMHuKKJby68qc4gcq4DFTK2n7KL5cGbTzdZ3XS_Xl-5C9uJL4xoCIrQQAvD_BwE
The one i was planning
https://www.evetech.co.za/xpg-sx8200-pro-256gb-pcie-m-2-2280-ssd/best-deal/5234.aspx
Since I only want to use it for the OS even the 256GB is proably to much want 120GB if that will be enough for the OS.
RGB is a benefit on the components, planning RGB case lighting as the main lighting plus the fans also RGB.
Also have some sleeved cables since I have a window
https://www.evetech.co.za/bitfenix-alchemy-2-0-evg-psu-cable-kit-black-yellow/best-deal/4556.aspx
Will up the RAM speed then.
Is that mobo dual channel ram or qaud channel ram?
GPU
The one I was planning:
https://www.evetech.co.za/msi-rx-570-8gb-armor-oc-edition/best-deal/3810.aspx
The one i think i should rather have then:
https://www.evetech.co.za/gigabyte-aorus-radeon-rx-580-8gb/best-deal/2700.aspx
would that gpu be better if so i can see so it is not such a big price jump.
https://linustechtips.com/topic/1035792-some-build-advice/#findComment-12319459
i know... it's tcl again qcl...
not really a need for nvme imo, but that aside
then i would recommend going up to the b450 tomahawk or pro carbon from msi, those have more rgb headers and a bit better vrms
ryzen in general is dual channel, but it does have 4 slots
that's a good one
it's a nice bump, I highly recommend it as it's on par with the 1060 6gb
https://linustechtips.com/topic/1035792-some-build-advice/#findComment-12319490
that's a good one
whats tcl and qcl?
so in your opion i should rather not bother with nvme for the os and just put it on the main sata ssd?
there will be 3 RGB fans and 1 or 2 light strips.
will check out those mobo's
i just want 16GB as Linus once said it enough for the everyday user (i think not sure will have to re-watch that vid)
will ugrade the GPU then.
did not think of all this when i started out, you are helping a lot, thank you.
https://linustechtips.com/topic/1035792-some-build-advice/#findComment-12319596
Just now, Charlie23 said:
whats tcl and qcl?
a dram type, tcl stores 3 values per chip, qcl 4, but is a bit slower
I would say for most usecases a cached sata ssd (like the 860 evo and mx500) will do you pretty well
ah, I would look into the cooler master mb511, that might be ideal for you
and there's nothing wrong with that. 16 gigs of 3000+ mhz is highly recommended as i mentioned above
no problem... I'm kinda bored sometimes... well sometimes, quite a lot
btw, we have a reputation system, so if you don't mind...
https://linustechtips.com/topic/1035792-some-build-advice/#findComment-12319610
Okay in the end will cut out the nvme ssd for now maybe upgrade later.
Yes that case although more expensive, it includes RGB fans which i will cut from my list.
HaHa been keeping you busy.
will draw up a excel sheet to show the diffrences really want to see what i get to save.
https://linustechtips.com/topic/1035792-some-build-advice/#findComment-12319983
what do you think?
https://linustechtips.com/topic/1035792-some-build-advice/#findComment-12320168
12 minutes ago, Charlie23 said:
yet another price focused decision. so what rather? can't have it go poof and blow up my system.
antac isn't that bad... i just never seen it before
i would suggest to look into the psu tier list down my signature, and select at least a 450 watt tier c or higher
https://linustechtips.com/topic/1035792-some-build-advice/#findComment-12320258
That psu is 850W but i can have a corsair 750W For a little less.
tier c? whats that?
But how do i figure out how much power my psu should have?
https://linustechtips.com/topic/1035792-some-build-advice/#findComment-12320278
tier c? whats that?
you would have enough with a good 450, but you can take a 550 if you want to be sure. tier c is a tier in that psu tier list 3.0 link in my signature. the best way is to look up reviews of some parts, you can easily found power usage in it
https://linustechtips.com/topic/1035792-some-build-advice/#findComment-12320343
o excelent more savings,
https://www.evetech.co.za/fsp-hyper-k-600w-80-plus-gaming-power-supply/best-deal/5216.aspx
https://www.evetech.co.za/corsair-cx-series-cx650-650w-atx-power-supply/best-deal/4790.aspx
will make sure about power requirments then
https://linustechtips.com/topic/1035792-some-build-advice/#findComment-12320465
22 minutes ago, Charlie23 said:
i would definitely thoose the cxm out of those
tho once again, you really don't need 650, 550 or even 450 is enough, as that system will pull around 300 watts
https://linustechtips.com/topic/1035792-some-build-advice/#findComment-12320540
Okay what about this then?
https://www.pcshopper.co.za/coolermaster-masterwatt-lite-400w-power-supply.html
https://linustechtips.com/topic/1035792-some-build-advice/#findComment-12321673
Just been looking around, whats is the G for on the CPU name, i found the same CPU but without a G in the name and it costs less.
https://www.pcshopper.co.za/amd-ryzen-5-2600-processor.html
https://linustechtips.com/topic/1035792-some-build-advice/#findComment-12321693
11 minutes ago, Charlie23 said:
no... tier d...
G is for intergrated graphics. this one actually has 2 more cores and 4 more threads
https://linustechtips.com/topic/1035792-some-build-advice/#findComment-12321700
1 minute ago, LukeSavenije said:
no... tier d...
Okay to tier d then...
Which do you think then as I am clearly incapable of picking one?
https://www.pcshopper.co.za/desktops/storage-components/power-supplies
https://www.evetech.co.za/PC-Components/corsair-power-supply-78.aspx
So since i will have a gpu won't the g-less one be better?
more threads and cores for 3d renders? or gaming?
https://linustechtips.com/topic/1035792-some-build-advice/#findComment-12321720
https://www.pcshopper.co.za/corsair-cxm-series-cxm550-550w-power-supply.html
this one is pretty good from my personal experience
the one without g will be better already, because you don't have to share pcie lanes in a intergrated gpu, and the display output comes out of the gpu anyway. more cores and threads in gaming is getting more important these days, many games can utilize 8 cores already
https://linustechtips.com/topic/1035792-some-build-advice/#findComment-12321759
Okay change made, and it is less expensive which is even better
scrapping the sleeved cables as the cables are already black from that psu
cpu change made too.
Is that a atx board  and case or matx (matx i smaller i think)
is there a huge differnece between the two price and perfomence. if it is not then don't really care.
I hope this config will be good for several years. don't need to upgrade soon i hope.
https://linustechtips.com/topic/1035792-some-build-advice/#findComment-12322195
