Hi y'all... I use some help.
I use a Razer Death Adder, which I really like, and a QCK pad. I've always had a problem with cloth pads where my mouse gets stuck while I'm moving it. The surface is clean, but the mouse doesn't glide so easily - as if it's running over sticky syrup or something.
This probably stems from the fact that I sweat a lot when I play, and my pad gets drenched. I've lately been using wipes and powder to help with this. I also press down hard with my hand when using my mouse, which obviously creates more friction. I've been trying to practice not pressing as hard, but I naturally do it.
Anyone have any suggestions? I suppose I need a pad that works well for someone who presses down hard when using their mouse, and also allows for easy movement without feeling "sticky" under these conditions. Thanks so much.
https://linustechtips.com/topic/1035658-mouse-pad-help/
Get a hard mousemat rather than a soft one
https://linustechtips.com/topic/1035658-mouse-pad-help/#findComment-12316688
While I agree that hard pads can help with smoothness, I have a better middle ground. Hard pads need to be cleaned often, and so does glass. So, to get the nice glide of glass and the ability to press into the surface, I recommend the Artisan https://www.amazon.com/ARTISAN-Gaming-mouse-Shiden-FXSKXSMB/dp/B07F5V7JVN Ninja FX Shidenkai. Yes, expensive, but worth it. Unlike normal glass pads, you can roll this up, and press into it.
-Django
https://linustechtips.com/topic/1035658-mouse-pad-help/#findComment-12316888
-Django
Optical (death adder) wont track well on a hardpad especially if it has a glossy surface or flat surface that has no texture such as glass
I think there's something wrong with the mouse..i assume the mouse feet is about to wear out or something.
Gaming Mouse Buying Guide (Technical Terms,Optical vs Laser,Mice Recommendation,Popular Mouse Sensor,Etc)
[LOGITECH G402 REVIEW]
I love Dark Souls lore, Mice and Milk tea  ^_^ Praise The Sun! \[T]/
I can conquer the world with one hand,As long as you hold the other -Unknown
Its better to enjoy your own company than expecting someone to make you happy -Mr Bean
No one is going to be with you forever,One day u'll have to walk alone -Hiromi aoki (avery)
BUT the one who love us never really leave us,You can always find them here -Sirius Black
Don't pity the dead,Pity the living and above all those who live without love -Albus Dumbledore
https://linustechtips.com/topic/1035658-mouse-pad-help/#findComment-12317074
I used to own a death adder and it worked great on a glass pad becaue there was like the swquihsy stuff under it
https://linustechtips.com/topic/1035658-mouse-pad-help/#findComment-12317169
-Django
Thanks Django. That sounds like what I might need. It's actually not the mouse feet. The mouse is only a month old and the feet don't show any wear.
I think it's really just getting caught in my cloth pad because I press so hard and have sweat in it.
https://linustechtips.com/topic/1035658-mouse-pad-help/#findComment-12317445
I dont get...there's 2 type of hardpad...a hardpad with hard surface (not cloth)
Image result for a hard pad
 and with a cloth surface.
Now a hardpad with a cloth surface is just a clothpad..if that is what you are referring to then yes optical will track well on that..but if its the 1st one then it wont track well unless you're using a laser sensor.
https://linustechtips.com/topic/1035658-mouse-pad-help/#findComment-12318910
