Will wireless charging still work?
Go to solution Solved by Lurick,
Yes, it will work just fine.
Was wondering if I placed the magnet into my phone to protect it from dirt and also just be able to charge it with the wire, will I still be able to use wireless charging or will it interfere, thank you!
CPU: Ryzen 7 1700 @3.85Ghz, MotherBoard: Asus ROG Strix X370-F, RAM: G.SKILL TridentZ RGB Series 16GB 3000Mhz
GPU: GALAX GeForce® GTX 1080 Ti EXOC White, Case: NZXT S340 Elite Matte White, Storage: Samsung SSD 850 EVO 500GB, PSU: Corsair CX650M
https://linustechtips.com/topic/1035463-will-wireless-charging-still-work/
ah ok much thanks!
