How to switch monitor ? (hard)
Hardquestions
Go to solution Solved by wanderingfool2,
45 minutes ago, Hardquestions said:
I have 2 monitors and 2 keyboards.
When i am at monitor No2 i cannot see monitor No1.
On display settings i have selected show only No1.
When i want to watch at No2 i go over to monitor No1 and turn it off.
How can i do that without having to go to monitor No1 and turn it off?
I am assuming you mean software switching?  Like a macro key or something (I've run into a situation where I need to switch between different monitors and always opening up the software to do it feels slow and clunky).
The solution I used was create .bat files with the commands
displayPrimary.bat
Inside the file put
DisplaySwitch.exe /internal
displaySecondary.bat
The text being
DisplaySwitch.exe /External
You can do the same for extend and clone.
so wait... you have two monitors, but you only use one at a time? so you turn monitor 1 off to watch on monitor 2? that doesn't even make sense to have 2 monitors then...
what yo should do is have them together, so then you can use both of them, otherwise its pointless to have 2
th first thing to do is to try and find a remote for that monitor so you can use it like a tv
13 minutes ago, Hardquestions said:
Ye it does i have one for my bed and one for my desk.
the second thing would be to rig up a system that would press the power button when you pull a peice of fishing line or something, other than that idk how you could do that other than sell the other monitor and buy a tv
It is a TV. I just said monitor to simplify the problem.
saying monitor actually misleads the answers, since tvs and monitor are actually vastly diferent
displayPrimary.bat
Inside the file put
The text being
3735928559 - Beware of the dead beef
I've been in your situation before, and know how frustrating it can be to not know the command line for something.
Glad it worked
