Okay, so I want my first tower, and  I just spent a good hour browsing differnt websites offering pre-builts and I'm more lost now than anything really.
I don't know what is good, and what is bad.  I just want a  clear answer, what would be a good gaming computer within the budget of 2000 bucks.
I'm not a  graphics whore, I'm more of an FPS whore. I just want the games to run good, they don't need to look good. So if I need to make some cuts with the budget, I'm willing to cut there.
I'm very lost and I'm just looking for any help to point me in the right way
Thanks for any help you can give <3
https://linustechtips.com/topic/1035117-first-tower-help/
Thanks for any help you can give ❤️
First off, Welcome to the forum! :)
Second, do you have any specific companies you like more then others?
Third, is there a possibility I could convince you to build your own? While the system will perform about the same for the budget (maybe slightly better), you will almost always get higher quality components when building it yourself.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/1035117-first-tower-help/#findComment-12312236
To point you in the right way, every user on the forum is going to say to build your own, and you should
Its super easy and not a bad thing to know. If you can build a lego set, you can build a pc
For 2000 bucks you can get a 9700k and a 2080, which is fairly high end. What type of monitor do you intend playing on?
https://linustechtips.com/topic/1035117-first-tower-help/#findComment-12312237
for $2000 you'll definitely get both
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1035117-first-tower-help/#findComment-12312239
1)  Thank you so much!
2) I pretty open  there
3) My fine motor skills are trashed. While building my own would be better, I  would most likely break something. Lol. I don't trust my self with such costly stuff. I know,  I would much rather build my own but oh well.
https://linustechtips.com/topic/1035117-first-tower-help/#findComment-12312248
As I just now stated, my fine motor skills pretty much stop me from building my own.
As for monitor, I have a total of 3000$ in my tower fund, I'm going to look at monitors once I have a tower picked out
https://linustechtips.com/topic/1035117-first-tower-help/#findComment-12312255
https://linustechtips.com/topic/1035117-first-tower-help/#findComment-12312262
Are we talking generally clumsy or are we talking parkinsons or something? Even still, a friend to help out wouldn't be so bad, and with one person building, a pair of extra hands, even shaky hands, are useful.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1035117-first-tower-help/#findComment-12312270
In facs class it once took me 30 minutes to thread the needle, and that was my quickest time.
And I don't have friends irl
https://linustechtips.com/topic/1035117-first-tower-help/#findComment-12312278
well thankfully building a PC doesn't require the precision of something that small, for the most part.
I can make a new parts list that would be a lot easier to work with, how good are you with a screwdriver? That would be the only challenging thing.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1035117-first-tower-help/#findComment-12312291
wait would that part list you provided before work? If so i'll just jump the shark and do it
https://linustechtips.com/topic/1035117-first-tower-help/#findComment-12312296
Oh yeah, that part list would all work out of box. PCPartPicker.com has a built in compatibility filter, so you'd have to disable it to put parts together that don't work.
The PC case has glass so if that's something you were worried about it can be changed.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1035117-first-tower-help/#findComment-12312304
Since fine motor skills are not in your wheelhouse, I'll skip the back and forth of "Build your own" vs buy a prebuilt, and just link one.
https://store.hp.com/us/en/ConfigureView?langId=-1&amp;storeId=10151&amp;catalogId=10051&amp;catEntryId=3074457345618972819&amp;urlLangId=&amp;quantity=1&amp;jumpid=ma_omen-gaming_product-tile_desktops_1_4wp44av-1_omen-obelisk-desktop
Use this config page and change these options. (pasting the full name from their website
Processor:
8th Generation Intel® Core™ i7-8700
Memory:
HyperX® 16 GB DDR4-2666 SDRAM (2 x 8 GB)
Optane:
(none)
Storage:
256 GB PCIe® NVMe™ M.2 SSD
Second Storage:
2 TB 7200 rpm SATA
Graphics Card:
NVIDIA ® GeForce ® RTX 2080 (8GB GDDR6 dedicated)
Power supply:
500 W Bronze efficiency power supply
Everything else you can leave as is.
If you have a best buy, frys or other box computer store, you can go there and get a similar configuration.
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/1035117-first-tower-help/#findComment-12312307
Processor:
Memory:
Optane:
(none)
Storage:
Second Storage:
2 TB 7200 rpm SATA
Graphics Card:
Power supply:
Alright! I'll look at both! thanks guys!
https://linustechtips.com/topic/1035117-first-tower-help/#findComment-12312311
