Help Picking A Laptop
Go to solution Solved by genexis_x,
All with 2060/1060 GPU:
Dell G7 7590
Dell G5 5590 - optional 144Hz (default low sRGB IPS)
Asus GL504GM
HP Omen 15-dc0046tx
HP Omen 15-dc0118tx - low sRGB IPS
(other options: any HP Omen 15 dc with 70Wh battery and no GSYNC. any HP Omen 17 without GSYNC)
Dell G7 7588 - low sRGB FHD IPS
Dell G5 5587 - low sRGB FHD IPS
Let me know if you have other options in mind
(Im from australia so if suggestions are made could you please use links from there . Thanks) Hey guys, so I'm in a dilemma. I don't want to spend 3k on a laptop but its looking to be that way.
I want a laptop that can do low level vr development, c++ encoding, unity development. And also from time to time play some games(I don't mind play mid low settings and play a lot of games from 2015 and before)
Can someone please help me to figure out laptop suggestions?
https://linustechtips.com/topic/1034956-help-picking-a-laptop/
problem is, I have no info on online stores in AU
Budget? Need Quadro? Any preference on weight and battery life?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/1034956-help-picking-a-laptop/#findComment-12310962
Hey sorry, so some stores that might include some of the laptops you recommend are msy, pc case gear, mwave, Harvey Norman, good guys, jb hi fi.
No quadro is needed, most of the stuff I do is comparable to what a gamer needs but more cores I've heard is better(and I've noticed can be better but a 4 core minimum is good)
My budget is ideally 2k Australian and I can go up to 3k but I'd rather not. That roughly translates into 1500-2300k usd.
I'll mainly be using the laptop before I go to bed or during uni or whenever I'm out so a nice battery is good, so at least 6 hours would be good. With weight, id rather it not be some huge bulky piece of kit. And id rather something a bit more slim. Um if you need any more of the details just reply back?
https://linustechtips.com/topic/1034956-help-picking-a-laptop/#findComment-12313616
Did you need more info Gene or is there something else? Sorry if I'm being a bit needy etc
https://linustechtips.com/topic/1034956-help-picking-a-laptop/#findComment-12318912
Will get back to you soon, I'm a bit busy lately
Desktop specs:
https://linustechtips.com/topic/1034956-help-picking-a-laptop/#findComment-12319041
Dell G7 7590
Asus GL504GM
HP Omen 15-dc0046tx
Desktop specs:
https://linustechtips.com/topic/1034956-help-picking-a-laptop/#findComment-12326190
Dell G7 7590
Asus GL504GM
HP Omen 15-dc0046tx
out of all those which would have the best colour accuracy. I'm out of that list looking at the two dells here. I was thinking about the 2060 one but i've heard the thermals aren't the best in 2060  laptops. also sorry if your not from the us
https://linustechtips.com/topic/1034956-help-picking-a-laptop/#findComment-12338897
As long as it has 300 nits 72% NTSC display or 144Hz display, the colour quality is good
Since both models don't have reviews yet (actually there is, the thermal performance is questionable), I suggest you to wait for reviews first
Desktop specs:
https://linustechtips.com/topic/1034956-help-picking-a-laptop/#findComment-12339367
I can snag a Strix Scar II with a 1070 and a 256gb ssd, for about 2000(1436.36 usd) -2500(1795.45usd) aud(2000ish dollars from ebay with a discount code or 2500 from a wholesaler ) what are your thoughts on this laptop
https://linustechtips.com/topic/1034956-help-picking-a-laptop/#findComment-12342338
runs too hot, 1060 is fine
Desktop specs:
https://linustechtips.com/topic/1034956-help-picking-a-laptop/#findComment-12342511
