OBS Settings R5 2600 issues? Or Normal?
Solved by Skiiwee29,
Get rid of the rescale option in Output. You are double dipping it with that since you are already downscaling it in the Video section. Secondly, the blurring you are seeing is compression artifacts from Twitch's side, not yours. Nothing you can do to correct that. Lastly, 6000 bitrate is the maximum twitch allows. Drop your bit rate down to a more manageable rate like 4500 or 5k which will produce a great video on your side. Again, nothing you can do about the blurring etc, thats all on the compression from twitch re-encoding the video stream.
