Yes, it will just technically need to be 'overclocked' in the BIOS, either manually or by enabling XMP.
Simple as a Bios setting (XMP) turned on and your motherboard will tune the system to the RAM's specs. It's a good idea to make sure your ram is preferably on the board's QVL list... Not being on the list doesn't mean the ram won't work, but it may mean it will need some tweaking to run at proper speed and settings.
Most morherboard/memory QVL lists can be found on the motherboard maker's website.
Primary Rig:
CPU: AMD 7800X3D @ Stock PBO - Mobo: Gigabyte X670E AORUS Master
2 x 48GB G.Skill Trident Z Royal 6400MHz CL32 1.35V @ 6200MHz CL28-37-32-30 1.5V (still tuning)
CPU Cooler: EK AIO that will be being replaced when I get the chance - PSU: eVGA P2 1200W
GPU: Gigabyte RTX 4090 Gaming OC @ either 2595MHz @ 900mV or 2970MHz @ 1070mV
Case: Thermaltake View 91 - SSDs/HDDs: 1 Samsung 980 Pro 2TB, 2 990 Pro 2TB M.2s, 1 990 Pro 4TB M.2, 1 TeamGroup Cardea Z440 2TB M.2, 1 Seagate EXO X10 10TB HDD
Monitor: Samsung Odyssey G9 49" Super-Ultrawide 240Hz Monitor
