So I converted a linksys wifi router into a repeater a long time back but havent used it much since it is just slow and I dont have a long cord to use it anyway. I pulled it back out tho to used it for something but I wanted to access the router to change some settings. I typed in 192.168.1.1 which is the standard ip address to access linksys routers I think but it just wont load. Can someone help me access the settings?
https://linustechtips.com/topic/1034854-quick-help-accessing-wifi-repeater/
192.168.1.1 wont work anymore since it is no longer the router. Use your router's DHCP server list to find it's IP.
Since the Linksys doesn't do any DHCP, it is no longer the default gateway(this changes for large networks), which means it gets it's IP from another router.
Have you tried restarting it?
