Hello everyone I'm trying to use my Dell PE R210 as my streaming server. My system isn't good enough to stream 1080p at medium settings. The problem I am facing is that I'm trying to install the NDI plugin on the server. Nothing shows up when I ope up the OBS Studio to see. It clearly works on my PC. The server has an E3-1240v3, 8GB Ram and the OS is Windows server 2016. I'm guessing it's the OS that is the issue?
https://linustechtips.com/topic/1034219-obs-ndi-help/
Anyone? :(
https://linustechtips.com/topic/1034219-obs-ndi-help/#findComment-12307741
32 minutes ago, Karma12gaming said:
There is an NDI plugin for OBS. Will this help?
That's the one I downloaded. Nothing works. I think it's the OS. I'm not sure if it's supported on server OS.
https://linustechtips.com/topic/1034219-obs-ndi-help/#findComment-12314564
