Hi
I have been using a headset for sound bc my audio devices in my computer and monitor have not been working as it says that they are but I test them and nothing just got them 3 weeks ago and still nothing
My computer : Amd Ryzen 5 Vega 11 graphics
My monitor : LG Ultrawide 25 in.
Audio: LG Ultrawide (AMD High definition Audio)
https://linustechtips.com/topic/1034115-no-audio-need-help/
I suspect your monitor doesn't have speakers. It will still say it has audio but it can't output the audio itself, only through something connected to the audio jacks on the monitor.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
https://linustechtips.com/topic/1034115-no-audio-need-help/#findComment-12304473
2 minutes ago, MYLORD77 said:
So from here what can I do to get sound like buy speakers or what?
https://linustechtips.com/topic/1034115-no-audio-need-help/#findComment-12304484
It seems like you're doing fine with a headset, but if you want speakers you will have to buy speakers.
¯\_(ツ)_/¯
Desktop:
Laptop:
https://linustechtips.com/topic/1034115-no-audio-need-help/#findComment-12304556
