So, I finally got fed up with windows 10 and decided to switch over to linux because the update that I had (that was forced upon me without my permission, even after applying the DWS and Spybot anti-beacon programs back-to-back to which didn't work apparently) slightly corrupted it's own partition as well as screwing up the networking functions.  Not to mention some programs don't work properly anymore.
I installed linux and yeah, so far so good.  One problem:  The touchscreen's HID function is f***ed.    Every time I boot up into linux now I have to log in, and open up the terminal to run the command: sudo xinput disable <device id here, 10> and after 4 minutes it re-enables itself so that I have to re-run the command.  It's getting so annoying.
I now decided that I have no use for the touchscreen's HID function and so I will remove the module that enables the touchscreen's HID function to work instead!  But, one teensy-weensy little problem:  I don't know how to do that.   So I do ask kindly if anyone can help me and walk me through the steps of doing that?  Thank you so much in advance! :)
https://linustechtips.com/topic/1034092-help-me-please/
Big oof. yeah, this is actually the reason I haven't done my laptop over to Linux yet, my use case for it is touch dependent. What distro u got? I hear Ubuntu hurts less for this sort of thing, others are more hit or miss.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1034092-help-me-please/#findComment-12304334
Ubuntu 16.04.5 w/ kernel upgrade (UKUU).
And, define: "hurts less". XP
Every 3-4 minutes the mouse cursor goes sporadic like a crackhead, twitching around without me touching it.  So i Have to bother with running that same command over and over again.  XP
That and my desktop's IPMI management doesn't work. (another topic I posted about.)
https://linustechtips.com/topic/1034092-help-me-please/#findComment-12304392
as it, it tends to work (just tends to though), although Linux and touch support go together as well as dog food and Cuban cigars, at least for now.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1034092-help-me-please/#findComment-12304395
In that case, the HID function of the touch screen is the dog food of my laptop the cuban cigar.  XP
https://linustechtips.com/topic/1034092-help-me-please/#findComment-12304421
what does the dmesg say?
btw I think that would require recompiling the kernel, but I think solving that bug is a better thing to do
you could also try disabling the touchscreen module by blacklisting it or remove the x.org driver, are you using x.org right?
also 16.04 is pretty outdated for x.org drivers... would you mind try a live USB of Manjaro just for excluding any bug fixes even if not kernel related?
also, some touchscreen may require the firmware and could be the reason why it acts strange
One last thing. Why are you using xinput? Touchscreen should also be displaying as an xrandr display device
Edited by Guest
https://linustechtips.com/topic/1034092-help-me-please/#findComment-12305021
dmesg?
The thing is that I don't want the touch screen functionality.
The reason why I have been using the xinput command is that there's no one else with the same problem as I do so I have to search for a different term to go by and of course for whatever reason it works and isn't permanently disabling the HID function. The HID hardware aspect of the screen is screwed however the actual display panel is just fine.
https://linustechtips.com/topic/1034092-help-me-please/#findComment-12306485
21 minutes ago, Bendy_BSD said:
dmesg?
fine, you may want to identify the touchscreen driver by using "sudo lspci -vv" and find the driver it is using, by just finding the device name and the "kernel module in use" name, then you can blacklist it
if you give me the lsmod output I can probably tell you what module to disable, if you can't find it
https://linustechtips.com/topic/1034092-help-me-please/#findComment-12306576
Sweet! :)
Give me a few, I have some things that I need to do and I'll give you the output.  :)  And thank you so much for helping me man.  ^^
https://linustechtips.com/topic/1034092-help-me-please/#findComment-12307508
For xorg things, you can try and experiment with a file in /etc/X11/xorg.d/ (I might be wrong with the path here) for the touchpad config.   I've done that before with mouse settings to turn accel etc off.  Might be worth looking into.
"Anger, which, far sweeter than trickling drops of honey, rises in the bosom of a man like smoke."
https://linustechtips.com/topic/1034092-help-me-please/#findComment-12309604
Thanks man.  :)
https://linustechtips.com/topic/1034092-help-me-please/#findComment-12309775
