Yeah, a 1060 would work because it has a PCIe x16 slot (if Intel's site is to be believed.)
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1033959-help-for-graphic-card/#findComment-12303064
The 1060 will be fine, the only thing I'm concerned about is the CPU. Which model is it exactly? Wouldn't want to bottleneck that gpu.
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
https://linustechtips.com/topic/1033959-help-for-graphic-card/#findComment-12303084
It's intel core i5-3220 3rd gen @3.3 ghz, 8gb ddr3 and a 1tb WD hard drive. It does not matter even if the game runs at 30FPS. I just want it to be playable
https://linustechtips.com/topic/1033959-help-for-graphic-card/#findComment-12304453
The game will run over 30fps no problem, but that CPU is fairly weak. If you want to stay on the same motherboard, look into getting the i7 2600k at some point. eBay and Ali Express may have it pretty cheap so take a look there.
PC #1
PC #2
Corsair H80iGT AIO
Laptop
https://linustechtips.com/topic/1033959-help-for-graphic-card/#findComment-12305394
thank you for the help
https://linustechtips.com/topic/1033959-help-for-graphic-card/#findComment-12305503
