Kali Wi Fi problem
Go to solution Solved by PD_Defalt,
Just now, Lukyp said:
If the issue is your internet connection, you can run a tethering connection from your phone
Once you are done follow those steps
sudo apt update
sudo apt install git
git clone https://github.com/neurobin/MT7630E
cd MT7630E
sudo make
sudo make install
then reboot
Ty
Hi, I just installed kali2 4.18 (I think it's the correct version) and I have a mediatek mt7630e card and I need someone to help me to download and install the drivers step by step
I can not connect my laptop to a wired network because of my damaged ethernet port.
Counting that I installed it for less than an hour and I have little experience in Linux
Laptop: Asus F550cc
https://linustechtips.com/topic/1033596-kali-wi-fi-problem/
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
https://linustechtips.com/topic/1033596-kali-wi-fi-problem/#findComment-12299542
1) Don't install Kali. It's intended to be used as a live environment. Using it as anything else is asking for trouble.
2) No offense, but if you have no experience with Linux you shouldn't be using Kali either way. It's a pentesting tool, not an environment to learn Linux in.
Install Debian or Ubuntu and then follow the instructions on the github page @Tsuki posted.
sudo chmod -R 000 /*
https://linustechtips.com/topic/1033596-kali-wi-fi-problem/#findComment-12299561
6 minutes ago, Sauron said:
1) Don't install Kali. It's intended to use as a live environment. Using it as anything else is asking for trouble.
this is very true.  Kali is not meant to be used as a full blown install.(performance is also shit)
if you want to use a pentesting distro fulltime, consider Parrot Security OS instead.  its basically just debian with all the tools installed
|Specs in profile|
https://linustechtips.com/topic/1033596-kali-wi-fi-problem/#findComment-12299586
I noticed ... well, anyway, you would recommend an OS to learn how to use linux
https://linustechtips.com/topic/1033596-kali-wi-fi-problem/#findComment-12299666
Laptop: Asus F550c
sudo apt update
cd MT7630E
sudo make
sudo make install
then reboot
Edited by Guest
https://linustechtips.com/topic/1033596-kali-wi-fi-problem/#findComment-12299668
sudo apt update
cd MT7630E
sudo make
sudo make install
then reboot
Ty
https://linustechtips.com/topic/1033596-kali-wi-fi-problem/#findComment-12299671
Usually I recommend Ubuntu MATE, but any Ubuntu flavor or derivative will be just fine for a new user.
https://linustechtips.com/topic/1033596-kali-wi-fi-problem/#findComment-12300625
