Hello everyone :) this is my first time here ,
anyway i have been thinking of upgrading my system .  i have an msi z370 tomahawk motherboard and i'm thinking of getting an i7 and an rtx 2070 . and i don't know what to chose an  i7 8700k or i7 9700k . i really want to get a 9th gen but i heard that they have a compatibility issues . so what do you think and what is your opinions .
thanks.
https://linustechtips.com/topic/1033520-need-help/
if u won't delid the 8700k, just get a 9700k
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1033520-need-help/#findComment-12298818
the 8700k runs hotter than a 9700k, they perform very closely to each other, so if you are not delidding the 9700k is better.
https://linustechtips.com/topic/1033520-need-help/#findComment-12299053
5 hours ago, MilkTeaAndTwix said:
what about the motherboard ?
you can flash the bios so it runs a 9700k, if you don't want to/can't flash due to lack of a current cpu, then you'd have to go with the 8700k
https://linustechtips.com/topic/1033520-need-help/#findComment-12300559
I don't understand.
You are thinking about upgrading but you already have a Z370?
What CPU do you already have?
What are your computing needs?
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1033520-need-help/#findComment-12300720
4 minutes ago, MilkTeaAndTwix said:
i have an i3 8100 and gtx1050ti
I would say try to get a rtx 2060 and see how you like the performance, first.
It might bottlenck a little at lower resolutions and in some heavily threaded games, but it might be good enough.
If you are still not satisfied, then I would recommend an 8700k because the performance difference isn't huge and there's a $50 difference.
https://linustechtips.com/topic/1033520-need-help/#findComment-12303360
Well I'm planning to give my niece the graphics card and cpu, so you are recommending the i7 8700k?
https://linustechtips.com/topic/1033520-need-help/#findComment-12305568
Here's a more objective review of the processors.
https://www.gamersnexus.net/hwreviews/3421-intel-i7-9700k-review-benchmark-vs-8700k-and-more
Quote
Conclusion
The Intel i7-9700K received ample criticism at unveil for being the first “gaming,” S-class i7 in recent history to drop hyperthreading. The move was accompanied by an increase in physical core count to 8C, but followed the previous move from 4C/8T to 6C/12T, and thus felt like an odd middle-step that had forgotten the lessons learned by the 8700K. The decision left enthusiasts feeling ripped-off; rather than a clear improvement in the product category, Intel had made a sort of lateral step.
Now that we’ve tested it, we can see that benchmarking positions the 9700K oft superior in gaming tasks, largely a result of frequency, to the preceding 8700K. This doesn’t remain true in every case, like in Blender workloads where the additional threads of the 8700K prove advantageous. The price increase of the 9700K over the 8700K also feels off-putting, and so the gains the 9700K makes in gaming are lost when considering the price increase. At the same price, it’d be more tenable, but an increase to $400 to $430 is unpalatable in the face of Intel’s similarly performing i7-8700K at cheaper prices.
The move did not feel productive for Intel. The 9700K is fine. It’s not a bad product, it does well in testing (overall), and it both wins and loses some tests, as any product would do. The oddity is just that it’s losing tests against its predecessor, even when those are simple tests of value, not necessarily performance. This was true for the likes of the RTX 2080 as well, for instance, where performance was fine, but value was a clear regression from the previous generation. We feel similarly about the 9700K. We need to see price come down to around where the 8700K is – around $350 – to really feel comfortable with the 9700K. Even then, it feels like an odd, lateral move from the 8700K before it.
Personally, as someone with an 8700k, there's no way in hell I'd "upgrade" to any of the 9th gen chips, despite having the "upgrade path" to do so.
If I were choosing between them right now without either, I would still choose the 8700k because its more efficient, is $50 cheaper, and performs pretty much equal to it at equal frequencies. It's also easier to delid than the soldered 9700k.
https://linustechtips.com/topic/1033520-need-help/#findComment-12305621
Thank you very much ❤️
https://linustechtips.com/topic/1033520-need-help/#findComment-12307895
