So my father recently upgraded our internet to 1GB speed up from 100 Megabytes, now with my Ethernet I get the same 4 ping with 100 mbps upload and download but on wifi we get 4 ping with 340 mbps download and upload. Should I get a wifi card for my computer or stick with lan? I play intensive games and I am not sure if it will be better or not.
https://linustechtips.com/topic/1033314-need-advice/
That's because your NIC is capped to 100Mbps for some reason. You either need a new router, switch, or a 1Gbps capable NIC. If you can give us more information like models then we can help identify the problem.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1033314-need-advice/#findComment-12296830
I was typing while Lurick answered so what he said xD
If you're formally an engineer, avoid responsibility. That's what senior engineers get paid for.
https://linustechtips.com/topic/1033314-need-advice/#findComment-12296836
1 Gigabit and 100megabyte are pretty much the same. You should get your terms right but it seems like you are limited to 100mbps on some interface.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1033314-need-advice/#findComment-12296846
I mean he did say 1 GB/s speed, maybe he just has really fast internet now.
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
https://linustechtips.com/topic/1033314-need-advice/#findComment-12296922
Let me try to give you some more info but networking and connections aren't my specialty we upgraded from 100 megabits to 1 gigabit connection speed. Our router I believe is the Verizon Fios Quantum but we have a Orbi as our switch. I tried plugging in my ethernet directly to the router in multiple spots and to the Orbi and I get the same speed. And what a NIC?
https://linustechtips.com/topic/1033314-need-advice/#findComment-12300008
NIC = Network Interface Card, either wired or wireless in this case.
https://linustechtips.com/topic/1033314-need-advice/#findComment-12300131
