Need help with a GTX 1060 not working properly.
Solved by Squid04,
8 minutes ago, tarfeef101 said:Okay, couple things:
- I suggest you don't run anything intensive on that card right now. That GPU is not supposed to get that hot.
- As for fixing it, I see 2 good options
- RMA the thing. Easiest solution, and it clearly has problems that aren't your fault
- You could try flashing the BIOS, i doubt the hardware died. It is POSSIBLE electrostatic shock or wear on the connector killed the DP, and it is possible the fan connector got disconnected or they got ESD damaged as well. but not likely. Not sure how that will affect your warranty, so the safest option it just to RMA. But if this doesn't affect warranty for you, you don't care, or the warranty period is over anyways, that is an option that may help. (also checking to ensure the fan cable is plugged in for the GPU fans isn't gonna hurt, either. if you're comfortable taking the card apart, then it's a free excuse to replace the stock thermal paste with better stuff anyways
Yeah, I stopped using it for intensive stuff. Don't want to dmg it further. I contacted the company I got it from and they were willing to RMA it. Unsure if it's covered by the warranty or if it's still there. But we'll see. It failed by itself happily and hopefully. I assume they want to run tests on it before hand, kind of hope the issue is unfixable as that would mean they'd have to hand over a new one, rather than repair this unreliable one.
Very grateful for your help dude!
