Noise coming from a computer
Solved by BigDamn,
Sounds like a bearing in one of your fans. You can grease up the bearing (I use WD-40 even though people say not to) and it should clear that up. You can also replace just the fan, no need to replace the heatsink.
smush ·
Posted in CPUs, Motherboards, and Memory2 -
asdasdasdasdasdasd ·
Posted in Hot Deals1 -
RipperDoc5456 ·
Posted in Troubleshooting6 -
Nebcs ·
1
FancyPants101 ·
