Does anyone know of anywhere that sells dust filter mesh in largish sizes - W45cm x L45cm+ in the EU?
It's for a DIY case
Monitor: Alienware AW2518HF CPU: 9900K @ 5.1GHz Heatsink: 2x360MM Custom Loop GPU: MSI GeForce RTX 2080 Ti GAMING X TRIO RAM: Patriot Viper Steel DDR4 2x8GB 4400Mhz Mobo: Asus Maximus XI Gene Case: Fractal Design Meshify S2 PSU: Corsair RM1000x Storage: Seagate Firecuda 510 2TB M.2, Adata XPG SX8200 PRO 256GB M.2
https://linustechtips.com/topic/1031703-eu-dust-filter-mesh/
It's for a DIY case
Not specially in the EU but Demciflex makes custom sized filters if you are in need of some. Another way to get large filters of that size would be to get fine meshed bug screen at the hardware store and to cut it to size.
https://www.demcifilter.com/Custom-Fan-Filters
https://linustechtips.com/topic/1031703-eu-dust-filter-mesh/#findComment-12283114
