My htpc laptop finally died, I recently upgraded my gtx780  to an RTX 2080 so im looking to build something on the cheap to throw that old 780 into. computer will mostly be used as a htpc but I would like to have a backup gaming rig or LAN party system.
Whats the cheapest system you can build, minus the GPU and storage? ideally I'd like to get under $500 also not against using used parts.
https://linustechtips.com/topic/1031207-help-building-budget-micro-itx/
which country? need os/monitor/peripherals?
2 minutes ago, NukeDuck said:
Matx would work too. just looking for a small form factor to sit in my entertainment center.
US
no monitors or peripherals
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  ($164.99 @ Amazon)
Motherboard: ASRock - B450 GAMING-ITX/AC Mini ITX AM4 Motherboard  ($118.98 @ Newegg)
Memory: G.Skill - Aegis 16 GB (2 x 8 GB) DDR4-3000 Memory  ($84.99 @ Newegg)
Case: Silverstone - SG05BB-LITE Mini ITX Desktop Case  ($46.47 @ B&H)
Power Supply: Corsair - SF 450 W 80+ Gold Certified Fully-Modular SFX Power Supply  ($65.53 @ Newegg)
Total: $480.96
Generated by PCPartPicker 2019-02-08 08:35 EST-0500
