When using CableMod's configuration tool, I foolishly undershot the number of cable combs I should get for the 24-pin ATX cable--I got 2, and I should have gotten 3 or 4.
I'm now on a hunt to find 1-2 white "open-style" cable combs that are compatible with my ModFlex (paracord) PRO cables.
http://www.performance-pcs.com/cablemod-cable-combs-4-28-slot-white.html#Details
^ I found these CableMod combs here. Does this compatibility chart predate their ModFlex PRO cables?...or is one of these sizes the perfect fit for me?
Any help would be greatly appreciated.
https://linustechtips.com/topic/1031082-cablemod-modflex-pro-cable-combs/
Mod Flex (paracord) sleeving was their first product that came out then came in the Mod flex (plastic) mesh. You will probably want size A from what I can see on that table.
@CableMod Should be able to help with that.
5 hours ago, CableMod said:
@Surge1 those combs would not be compatible - our pro cables are 3.4mm thick and those combs do not have proper sizing for the pro series.
Thank you for the quick response. Sad day... what do you suggest? Are you positive that Size C will not work (tight fit)?
If not, would you recommend these? These are the only compatible combs I could find.
https://www.amazon.com/Pieces-24-pin-8-pin-Gesleeved-0-13inch/dp/B078PG71BR/ref=sr_1_3?ie=UTF8&qid=1549671480&sr=8-3&keywords=cable%2Bcomb&th=1
