1 minute ago, Runar Sandstaa said:
Also: the integrated RGB in the motherboard is constantly on.
That is not good.  The CPU and motherboard can't read each other.  Either the CPU is bunk or the motherboard is botched.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1030902-pc-wont-post/#findComment-12275721
I cant say for sure if you have what i just went through but i tried the whole 1 stick of ram test and even went as far as to buy another different brand motherboard and they both still said 00  .  It turned out to be a bad cpu that just up and died a few months after buying. Unfortunately without another mobo and cpu this is impossible tell whats bad. First try the ram test 1 stick at a time and in different slots but without a gpu in and not being ram and still getting 00 its probably cpu or mobo.
core ultra 7 series 2 , 48gb ram , zotac 4090 trinity oc ,z890 strix-e gaming , 7.1 kilpsch rp series , denon srh750 ,lg c3 77 inch , antec c8 curved wood case
https://linustechtips.com/topic/1030902-pc-wont-post/#findComment-12275749
Yes like I said earlier the 00 code means dead cpu.
https://linustechtips.com/topic/1030902-pc-wont-post/#findComment-12275807
From what i was told from asrock team it means no response from the cpu which could also mean defective cpu,psu or mobo , but i agree i think its probably cpu.
https://linustechtips.com/topic/1030902-pc-wont-post/#findComment-12275834
