So,
Just started streaming for fun, with some friends, And out of nowhere I just drop frames showing up on OBS - My bit rate was at 6k but I set it back to 3k and its still dropping frames pretty frequently I am not straming any crazy games, Its a 2D game - and its not even in full screen, Pretty sure its like 800x600. I do not think my internet is the issue as well.
Any ideas what to do?
This is showing it drop.
https://gyazo.com/c9b2dfc9f660407e2082b4a162b5eb4f
M Y  S T U F F
Ryzen  PC |~|  Ryzen 5 1600 | GTX 1060 6GB | G.SKILL Ripjaws V Series 8GB DDR4 DDR4 2400 x2 |  WD Blue 250GB SSD | Barracuda Pro 2TB  EVGA 650W 80+Gold |
Laptop |~| Legion Y530 | i7-8750H | GTX 1050 Ti 4GB | 16GB DDR4 2666MHz | 128GB SSD | 1 TB Hard Disk Drive, 7200rpm |
Macbook Air |~| 2.2GHz dual-core Intel Core i7 | Intel HD Graphics 6000 | 8GB of 1600MHz  512GB SSD |
Displays |~| AOC G2460VQ6 24" x2|
Keyboard |~| Corsair Gaming K70RGB
Mouse |~| Razer Lancehead Pink RG
Audio |~| HyperX Cloud II Audio-Technica ATH-AD700X
Microphone |~| Audio Technica AT2035
M y  R e v i e w s
Lenovo Y530 Legion Laptop.
More Coming Soon...
https://linustechtips.com/topic/1030653-dropping-frames-obstwitch-help/
2 minutes ago, Kdog said:
Could you screenshot and post your OBS settings? Specifically the output and stream option menus. Make sure to blur your stream key if visible.
Only other Output part is Recording.
but yeah
M Y  S T U F F
M y  R e v i e w s
More Coming Soon...
but yeah
1
Switch from software encoding to your dedicated card (should be 1060 for you based on your signature). Do some tests with that and see if you keep dropping frames. Also, try temporarily lowering your bitrate to 2000. Your machine and internet should be able to handle a bitrate of 3000 but you never know.
"Kieran just stole my girl!" - No-one
Discord: Kdog#7258
The only other option is "Hardware (NVENC)"
M Y  S T U F F
M y  R e v i e w s
More Coming Soon...
Alright, I did some research and dropped frames aren't from your pc stuttering as I thought first but instead your connection. Try lowering your bitrate as I suggested. Also, if you're on wifi it's possible that's causing your dropped frames. Try streaming to youtube or mixer to see if you're still dropping frames. it could be the twitch servers.
Discord: Kdog#7258
