I was wondering, is there anything I need to do when replacing my Motherboard, software related. I am switching from an HP board to an MSI. Also, is there anything I need to do in the BIOS, such as setup or anything. I've never actually built a PC, but I think I have a good understanding. Will also be changing my Graphics card, and likely adding an NVME SSD.
https://linustechtips.com/topic/1030607-motherboard-help/
Nothing in the BIOS, but it would be safe to run sysprep in Windows to clear out any drivers from your HP board.
https://linustechtips.com/topic/1030607-motherboard-help/#findComment-12273049
New windows license, probably good idea to do fresh install but jayztwocents doesn't and it works for him
You will need to set your ram speed appropriately and also set your drive boot priority etc
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1030607-motherboard-help/#findComment-12273057
1 minute ago, JoeyStrickGaming said:
@Crunchy Dragon Would I still need to use DDU for my graphics drivers if my current one is also AMD? Or can I leave it as is.
You don't need to do that, you're only changing your motherboard.
1 minute ago, Plutosaurus said:
New windows license
If you link your Microsoft account to Windows, you won't need this.
https://linustechtips.com/topic/1030607-motherboard-help/#findComment-12273067
Learn something every day.
Here's the low down:
https://m.windowscentral.com/how-link-your-windows-10-product-key-microsoft-account
https://linustechtips.com/topic/1030607-motherboard-help/#findComment-12273086
Just now, JoeyStrickGaming said:
@Crunchy Dragon and to do that, all I need to do is to sign into my computer with my Microsoft info, or is there an option I need to select.
You need to into your settings I believe to link Microsoft to Windows.
https://linustechtips.com/topic/1030607-motherboard-help/#findComment-12273088
