What power supply?
Go to solution Solved by WoodenMarker,
no but since I'm going today I thought I could buy it
The Seasonic 550 G would be my recommendation if you can shop elsewhere. http://pcpartpicker.com/part/seasonic-power-supply-ssr550rm
What psu should i get because my old one died. Im between a corsair cx750 and a corsair GS700.
CPU: AMD FX 8320 plus a hyper 212 evo
GPU: Asus Nvidia GeForce GTX 760 (OC)
HDD: 1TB WD
RAM: 8GB Crucial Ballistix
MOBO: Asus M5A78L-M LX PLUS
I want to know if on one i could overclock my cpu.
https://linustechtips.com/topic/103060-what-power-supply/
Get a cx600 or the xfx 600w psu, they are the same inside, which ever one is cheaper is the  one to get
Listen if you care.
https://linustechtips.com/topic/103060-what-power-supply/#findComment-1378673
Where are you shopping/located?
Unless you're planning to sli, a cx500 is plenty.
https://linustechtips.com/topic/103060-what-power-supply/#findComment-1378674
I have the GS 700 but I don't recommend it due to the lack of PCI connectors. The LED isn't really something you'll see so go for anything in the similar category of wattage.
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/103060-what-power-supply/#findComment-1378675
I'm personally not a fan of the GS series, have had a few underperform. I would say the CX 750 (or smaller if you don't want more cards) would be a good option. Also what brown said above ^^
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
https://linustechtips.com/topic/103060-what-power-supply/#findComment-1378684
Everything that they said^, but DO NOT overclock your 8320 on that board. If anything, undervolt it.
My Build Log on PCPartPicker FX-6300, ASUS M5A78L-M/USB3, MSI 7870 GHz Edition, Corsair Vengeance LP 1x8GB, 1TB WD Blue, Fractal Core 1000 USB 3.0, Corsair CX600, and my most recent addition that I've had forever and isnt new is a 80GB WD800 for Linux, Lenovo ThinkPad X131e, ASUS Transformer TF300T, Galaxy Note 3 Sister dropped it in a puddle I now have to use a Samsung Brightside, Beyerdynamic DT990 Pro 250ohm version, Blue Yeti  #TheRealKEH-JEFF | "Sometimes, if were lucky, in Australia, a family has 2 kangaroos to pick up the kids with" - marto | Your entry here | Remember kids; just because Linus has a video on it, doesn't mean that its the best choice | ts3.wferr.com the best TeamSpeak Abide by the CoC | Looking for build help? Read this before posting |
https://linustechtips.com/topic/103060-what-power-supply/#findComment-1378708
I would get a XFX Core 550W if you don't plan to SLI in the future as it is enough to run this system. I wouldn't overclock your 8320 it is only a 3+1 phase and there are no heatsinks on the VRM.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/103060-what-power-supply/#findComment-1378772
the cx600 died in less than 3months so I don't know
Anomalies happen, make when i built pcs for money i got quite a lot of builds done, around 150, of those around 10 parts broke somehow, these things happen, it sucks but its not the psus fault in this case, a cx500 would be fine with the workload
Listen if you care.
https://linustechtips.com/topic/103060-what-power-supply/#findComment-1378846
Seeing how your motherboard doesn't have support for SLI/CFX, you don't need a GS700 or CX750.
What is your budget and where are you able to buy from? The budget oriented CX500v3 can certainly power your system.
They aren't the same unit on the inside.
https://linustechtips.com/topic/103060-what-power-supply/#findComment-1378920
cx600 and xfx pro series are exactly the same inside, its just that simple, just me i did a lot of psu research a while back for a roundup. Your info might be false
Listen if you care.
https://linustechtips.com/topic/103060-what-power-supply/#findComment-1379086
The CX600 is based on a modified DSA-II unit from Channel Well Tech. The XFX Core Edition 450-550w is based on the group-regulated S12II Bronze unit from Seasonic and the 650-850w model are the DC-DC regulated SS-***AT from Seasonic like the Corsair TXv2 series. They are not the same unit.
https://linustechtips.com/topic/103060-what-power-supply/#findComment-1379133
thanks I thinks I'll get cx750 because I need the watts for future upgrades
https://linustechtips.com/topic/103060-what-power-supply/#findComment-1379154
There is a serious problem with this thread, CX series is absolutely terrible. If your not running CF/SLI, overvolting, or OCing(CPU), then you will never need more than 450w.
 SeaSonic G Series SSR-550RM is great for the money, a little extra wattage too.
Hey look you found my sig.
https://linustechtips.com/topic/103060-what-power-supply/#findComment-1379160
future upgrades man.
https://linustechtips.com/topic/103060-what-power-supply/#findComment-1379173
microcenter
Only? Are you open to other US shops?
Unless you're dropping in 100 hdd's, a Seasonic 550 G should be plenty for any single gpu system.
https://linustechtips.com/topic/103060-what-power-supply/#findComment-1379180
in future I'm going with a better mobo and maybe sli
I doubt it would be a good idea since there would probably be a better single gpu solution when it comes time to upgrade.
In the case that you do sli, a good 650w is plenty.
https://linustechtips.com/topic/103060-what-power-supply/#findComment-1379229
you could be right, lucky that i had forgotten the websites name, shit would go down. Anyways apologies for doubting you
Listen if you care.
https://linustechtips.com/topic/103060-what-power-supply/#findComment-1379239
