When I'm running my pc during load (valley benchmark) after about 40 minutes my pc shuts down completely: no lights, no fans, no noise as if I had pulled the power chord from the wall. After the shutdown the power button does not work at all as if there's no power at all. In order to turn on my pc again I need to flip the psu's button to the off position and then to the on position. After that the power button works normally. Is the cause the power supply? The wattage is enough on paper. Is there anything else that might be causing it?
Components are
Ryzen 7 1700 @3.9Ghz 1.35v
Palit gtx 1060 6g overclocked +180mhz, +500
Msi x370 gaming pro carbon
Corsair cx550m 550 watt
https://linustechtips.com/topic/1030444-pc-total-shutdown-during-load/
It could be CPU overheating, what are the temperatures?
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
turn off your overclocks and see if it still happens
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
It seems to be stable in Valley benchmark with the GPU Overclocked and the CPU at stock. After I overclock the cpu to 3.8G at 1.3V it's stable for 2 hours in Prime95, however it crashes within 40 minutes in valley benchmark. Can the PSU be casing this? Valley shouldn't be stressing the CPU that much anyway.
