Ok recently i ran cat5 through my entire home and don't know whats best to do from here. My service comes down the riser into garage, there it connects to modem and ran outside underground and up into my attic of my home. From there i connected that into a old netgear router. From the netgear router ive ran hardwire to all 6 rooms. I have four kids that want less lag! So dad thought hardwire would be best! So far its working but i have no idea how well. Questions are have i done this right? Are there specific router and modems i should be using? is there a length i should not go past with cat5? any and all help is grateful thank you
https://linustechtips.com/topic/1029657-wired-connection-4-everyone/
why cat 5? at least go CAT 5e.  the max length as far as I know is 100m.
Favorite Threads: PSU Tier List
My Stuff n' Things
The Beast (My Rig)   |CPU: AMD Ryzen 7 7800X3D|  |Cooling: Noctus NHU12S Redux, 6x 120mm Noctua Redux|  |Motherboard:  Asus TUF B650-E WiFi|  |RAM: 4x8gb 6000 Corsair VENGEANCE RGB|  |Graphics Card: EVGA(RIP) GeForce RTX 3070TI FTW3|  |Power Supply: EVGA GT 850W|  |Case: Corsair 4000D Airflow Mid Tower Case(Black)|  |SSD: 1Tb SK Hynix Platinum P41 NVMe, 2Tb Inland Prime NVMe, 500gb Inland 2.5", 4tb WD Blue HDD|  |Monitor: MSI Optix MPG341QR 34" Ultrawide|  |Keyboard: Logitech G815|  |Mouse: Logitech G305|  |Audio Interface: FiiO K7 DAC/Amp|  |Headphones: Sennheiser HD6XX |Webcam: Logitech C920, Logitech C270|
My Network Rack  |Switch: Cisco Dell PowerConnect 5548P|  |Router: Unifi USG|  |Rack: 12U|  |Server: HP Z420|  |Services: Proxmox PVE, Wireguard, Pihole, NVR, NAS|
Aslong as you do not exceed the maximum length of 100 meters and all your network gear is 1Gbit it should be fine
(100Mbit are fine to if your internet connection is slower than that and you do not need to transfer files over your network to an NAS or another PC)
EDIT:
If it is really CAT5 than there is no reason for using 1Gbit network gear.
I cannot recommend using CAT5 because its not futureproof but if that is what you got for now its ok.
ANd it is definitelly better than WLAN
are u using a switch?
My Stuff n' Things
1 minute ago, DannyC.711 said:
As of now i have 250mbp speed but wanting to upgrade once is more available. What is this switch you speak of!
physically, it's a device with a bunch of ethernet ports. Functionally it takes the data from one port, usually from router and distributes it throughout network
Image result for simple router switch topology
Image result for desktop switch
from google the definition is:
A network switch is a computer networking device that connects devices together on a computer network by using packet switching to receive, process, and forward data to the destination device.
My Stuff n' Things
he's an enterprise switch. Cisco 3560 48-port
Image result for 3560 48 port
My Stuff n' Things
If you have more that two cables to plug in, I would not plug them all into your router...use a switch.
My Stuff n' Things
ok yea i need a switch then! just not one with that many ports i don't think! im running a total 7 or 8 hardwire lines. And yes as of now it go's from modem into router an then down to the boys rooms ,front room ,kitchen etc.   i can see what modem i have but not going in the attic today its too cold!    MOTOROLA SBG6782AC is the modem
I would look at a 16 port switch then to allow for additional expansion if that's needed. You can generally pick them up for about $50 to $100 depending on the model but just unmanaged is all you need so that should bring the price closer to the $50 price point.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
Why two?  Routers usually contain at least a 4 port switch!
