So the Be Quiet Silent Loop 280mm AIO cost about $175 for what I'm seeing and the 360mm version cost about $190. Is the 360mm version worth it for the extra 15 bucks?
I would assume if you're going with something like an 8700k/9700k/9900k, there is not that much of a difference. But what about overclocking Threadripper (If it even supports it) or i9 X-TREME Series (7940X, 7960X, 7980-XE, etc.)?
https://linustechtips.com/topic/1029515-silent-loop-280-vs-360/
slightly more performance and more noise if you ask me, that's what a normal 280mm vs 360mm aio of the same series usually behaves.
Unless one has a significantly bigger base plate, they will perform similarly.
Desktop benching:
https://linustechtips.com/topic/1029515-silent-loop-280-vs-360/#findComment-12263153
about a 10% increase in surface area going to the 360mm.
to me $15 is negligible for AIO pricing .. personally iI would go with whichever filled out my case better. If it fits a 360 and you put a 280 in, it would create an 8cm dead space at the end of the rad causing an unfinished look imo.
                                             ~~~~Started Folding - Feb 7, 2019~~~~
https://linustechtips.com/topic/1029515-silent-loop-280-vs-360/#findComment-12264929
