Hello
SO ive been using Hyper Xs for while, And they worked fine, but I now want to talk to one of my frineds so I plugged in the mic And all i hear is static... If I open discord all it shows it staitc bars and if I talk into it nothing comes up, If i do a hearing test I can hear the dings windows plays, But I cant talk into the mic... Ive tried to open sound/recording making it default nothings working... I also just re installed windows posible I dont have some kind of driver?
Thanks!
M Y  S T U F F
Ryzen  PC |~|  Ryzen 5 1600 | GTX 1060 6GB | G.SKILL Ripjaws V Series 8GB DDR4 DDR4 2400 x2 |  WD Blue 250GB SSD | Barracuda Pro 2TB  EVGA 650W 80+Gold |
Laptop |~| Legion Y530 | i7-8750H | GTX 1050 Ti 4GB | 16GB DDR4 2666MHz | 128GB SSD | 1 TB Hard Disk Drive, 7200rpm |
Macbook Air |~| 2.2GHz dual-core Intel Core i7 | Intel HD Graphics 6000 | 8GB of 1600MHz  512GB SSD |
Displays |~| AOC G2460VQ6 24" x2|
Keyboard |~| Corsair Gaming K70RGB
Mouse |~| Razer Lancehead Pink RG
Audio |~| HyperX Cloud II Audio-Technica ATH-AD700X
Microphone |~| Audio Technica AT2035
M y  R e v i e w s
Lenovo Y530 Legion Laptop.
More Coming Soon...
https://linustechtips.com/topic/1029510-headset-mic-help/
So I installed the Audio Drivers, The static is gone, but still cant hear myself. or make any sounds
M Y  S T U F F
M y  R e v i e w s
More Coming Soon...
https://linustechtips.com/topic/1029510-headset-mic-help/#findComment-12263075
10 minutes ago, K i a r a said:
Hello
Thanks!
There should be no issue with the mic unless it's failed.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/1029510-headset-mic-help/#findComment-12263076
M Y  S T U F F
M y  R e v i e w s
More Coming Soon...
https://linustechtips.com/topic/1029510-headset-mic-help/#findComment-12263080
Just now, K i a r a said:
If the mic failed you won't make any noise. Unless you accidentally muted yourself or have the audio recording device set wrong.
|King Of The Lost|
https://linustechtips.com/topic/1029510-headset-mic-help/#findComment-12263084
This is why I need troubleshooting help lmao.
M Y  S T U F F
M y  R e v i e w s
More Coming Soon...
https://linustechtips.com/topic/1029510-headset-mic-help/#findComment-12263089
Right click the volume icon and open sound settings, under input make sure it's set for your mic and you will be able to see if it's picking up any noise there.
|King Of The Lost|
https://linustechtips.com/topic/1029510-headset-mic-help/#findComment-12263093
Its not picking up any noise, No green bars.
M Y  S T U F F
M y  R e v i e w s
More Coming Soon...
https://linustechtips.com/topic/1029510-headset-mic-help/#findComment-12263102
Are you using the dongle that came with the headset?
https://linustechtips.com/topic/1029510-headset-mic-help/#findComment-12263108
On the Cloud II dongle there is a  volume up and down for the mic try turning that all the way up. If that doesn't work then that USB "sound card" dongle is probably bad.
|King Of The Lost|
https://linustechtips.com/topic/1029510-headset-mic-help/#findComment-12263109
Its just the one with the 2 3.5mm jacks
M Y  S T U F F
M y  R e v i e w s
More Coming Soon...
https://linustechtips.com/topic/1029510-headset-mic-help/#findComment-12263110
Talking rn, No sound cant hear myself.
M Y  S T U F F
M y  R e v i e w s
More Coming Soon...
https://linustechtips.com/topic/1029510-headset-mic-help/#findComment-12263115
