P20 Pro RAM Problem
I don't see any Problem here, instead i see a good working Ram Management.
Not used Ram is useless Ram.
It is GOOD, that so much Ram is actually in (good) use - beause it's filled with Cached data and Apps, that will be instantly up/ready, when you open them.
If 80% of your Ram would be empty, every App start would be slower, because it will have to reload from scratch.
That is the reason, why these "Ram Cleanup Apps" are 100% useless Garbage, that will do more Harm than good. They actually slower your device, and cause higher battery Drain, because the CPU will have to work everytime again by opening Apps over and over, and loading them into the Ram.
--> Delete them, don't use them. Android itself manages Ram very well already
Which process uses up how much Ram, you can see in th settings.
Should be "Settings --> Memory --> Memory used by Apps".
But i'm not sure if that's the patch on Huawei phones. My Oneplus has this under Developer Settings, which you have to unlock first (Phone info --> tap a few times on "Build Number")
Usually, after a fresh Reboot, you would have more free Ram, because there's "nothing loaded yet". This will show you, that your Ram management works flawless.
After a while using it, there are Data from all your recently used Apps, so they're ready to use whenever you open them again.
If you would now (on your screen) open a huge Game for example, and it needs more Ram than there's free available, the Android System itself will close older Apps in the background, making room for the new App.
