Liquid Cooler Lifespan or Water Going Bad
Liquid in it won't go bad. What is more likely to happen is evaporation of it. I've had two AiO's and both had evaporation issues. Mostly because I ran my AiO's quiet which means higher temperatures of the liquid. But after refilling my CM Nepton XL cooler, it's back to its original performance. This was after around 2-3 years of 24/7 running.
As for failure, regular tower heatsink has a lower probability of failure. AiO can fail on pump, leak, fan, evaporation of liquid, clogging etc. Air coolers can only really fail if they get so clogged with dust or fan failing. Theoretically heatpipes can leak but that's very rare. And even if everything else fails, it'll provide some passive cooling.
Personally, I don't think I'll ever go back to air coolers. AiO is just more practical because you can displace the heat to where you want, where tower coolers are always on top of CPU. It's just more flexible and higher performance despite possible higher failure rate.
It also greatly depends on hardware you have. If it's a Ryzen 3 or 5, just slap a medium sized tower on it and cal it a day. Hell, for most even the stock Wraith will be enough.
