Ark is the hardest game for me to run on my PC. Besides fallout 4 which is just acting weird. But I was looking into upgrading my asus fml 750ti. I can currently play it at 720p with mostly ok settings with 55-75 fps. But I want to run it at 1080p, even though my monitor caps at 900p, with mostly high settings. I dont think a gtx 1060 6gb will do so though, or Rx 580 8gb. I feel like ill need a 1070 or Vega 56 or 64. By the way, is it weird to have a 900p monitor that has a 75hz refresh rate?
https://linustechtips.com/topic/1029110-good-gpu-for-running-ark/
You'll want to run your games at 900p, running at native resolution is almost always a better experience than trying to upsample or downsample.
You're severely underestimating the GTX 1060 and RX 580, both cards are about triple the performance of your current card, and will have absolutely no issues with ARK.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
a gtx1070 can be had for $200~ on ebay. i assume your not trying to hurt the wallet.
There is no enemy. The foe on the battlefield is merely the manifestation of that which we must overcome. The doubt, and fear, and despair. Every battle is fought within. Conquer the battlefield that lies inside you, and the enemy disappears like the illusion it is.
