Mobo won't post
Go to solution Solved by TheMiddleDe,
Okay so it was posting... it just wasn't posting to my monitor because it was using to display port. i switched to an hdmi monitor and got it to post..... this was really anoying and it took me about 6 hours of tinkering to figure this out.
okay I opened my system to change my boot drive to the 960 pro and when i put the whole thing back together i'm not posting and i'm getting a q-code b6 which is Clean-up of nvram
I tried looking around to figure out what this was and the only clues i found was a forum where someone said it had something to do with the cmos so i cleared the cmos with the button on the back of my mobo. that didn't help so i pulled out and replaced the mobo battery. that didn't work so i pulled the batter and left it out for about 10 minutes to clear cmos normally.... that didn't work. so any ideas
Z270 Maximus IX Code
i7 7700k
16 gb ddr 4 3000 T-force night hawk
1080Ti
1Tb samsung 960 pro nvme ssd
https://linustechtips.com/topic/1029108-mobo-wont-post/
4 minutes ago, thinwalrus said:
And the drive is fully in the slot? Try reseating it, I got the screw in on my Asus board while the drive was not in.
I reseated it and nothing happened, same error.
also I'm not posting at all so even if the drive isn't detected i should be posting and should be able to get into the UEFI
so on that logic the next thing i did was just remove the SSD now all that i have connected is the CPU and one stick of ram and i'm still getting the same error b6
https://linustechtips.com/topic/1029108-mobo-wont-post/#findComment-12259815
https://linustechtips.com/topic/1029108-mobo-wont-post/#findComment-12259964
