Hey guys, i am just wondering if you can force a specific network... i have a bit of a problem with my mobile network as long as its on 4g i have signal when it drops to 3g i have no connection... I had an xiaomi redmi note 3 and it has a built in network select idk how to call it but you can select your network i will link a picture  https://imgur.com/a/JyY9KuF  idk if anyone knows anything how i could fix this issue... i have a samsung s8... Thanks for the replies.
https://linustechtips.com/topic/1028412-samsung-s8-mobile-network-problems/
I have the S8, i suppose this setting is on default as i never touched it, and it switch by itself to whatever is convenient.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
Yeah i do to but it doesnt work like it should whenever it drops to 3g the network is just shit then i switch on airplane mode on turn it off again and it goes back to 4g ? idk...
weird stuff mate, i don't know xD
