How is this build for a PC that can be used for normal home use, maybe very light editing/rendering, and very light gaming with some non-intensive games such as CSGO and League. I might stretch some overclocking on CPU and Memory since this is an APU Build.
CPU: AMD Ryzen 5 2400G 4C/8T 3.6Ghz RX Vega 11 APU (Best APU on market in performance and value; like 750 Ti and GT 1030)- $149.99
GPU: Obviously RX Vega 11 Integrated Graphics
MOBO: GIGABYTE B450M-DS3H (Obviously not the highest end but is capable of overclocking on the 65W TDP Chip and has 4 DIMM slots)- $75.99
RAM: ADATA GAMMIXX D10 (2x4) 8GB DDR4 2666 (Good for budget gaming and normal use, will overlock for Ryzen optimization)- $49.99
Cooler: Cryorig M9a (Budget tower cooler but can handle a little bit of OC)- $24.99
PSU: EVGA 450BR 80+Bronze (80+Bronze and enough for system)- $29.99
SSD: Inland 480GB SSD (Good for boot and some games+storage)- $49.99
Case: Not decided.- Under $20 though
https://linustechtips.com/topic/1028288-400-simple-home-pc/
You'll be just fine with that setup. I'm using that motherboard and a 2200G in another build without any issues. Getting a little over 70 fps in CSGO so you should be perfectly fine.
Ryzen 3800X + MEG ACE w/ Radeon VII + 3733 c14 Trident Z RGB in a Custom Loop powered by Seasonic Prime Ultra Titanium
PSU Tier List | Motherboard Tier List | My Build
https://linustechtips.com/topic/1028288-400-simple-home-pc/#findComment-12252880
