Help me please!
Go to solution Solved by Sir Asvald,
5 minutes ago, Acki said:
I can’t take it out one corner is still attached. Only left corner is still attached i dont know how to get it out.
57063487679__D77E7674-A503-429B-A1EE-8A68208C9669.MOV
Faceplam.. you need disconnect the wire and remove the screw that is holding the card in place...
3 minutes ago, Acki said:
Guys there is no space for the cooler where i can put it?
Mb: MSI H370M Bazooka
Cpu: I7 8700
Cooler: CM Hyper 412R
You need to take the motherboard out mount the backplate and then put the motherboard back in. and it will fit.
https://linustechtips.com/topic/1028067-help-me-please/#findComment-12250850
install the cooler with the motherboard outside of the case.
https://linustechtips.com/topic/1028067-help-me-please/#findComment-12250860
2 minutes ago, Acki said:
How i can do that coz i have my graphic card on?
?? take your card out?
https://linustechtips.com/topic/1028067-help-me-please/#findComment-12250886
Dude, just disassmble everything, take out the mainboard and mount the backplate according to the manual. This isn't rocket science, a little bit of common sense is enough. If you're not comfortable with it, take it to someone who is or send back the cooler. There's nothing else to say here. You don't have an issue with compatibility, just with lack of know how.
P.S.: The thread title is there to give initial information about your topic/issue/problem/question. "help me please" is not helpful for anyone on a forum.
Use the quote function when answering! Mark people directly if you want an answer from them!
https://linustechtips.com/topic/1028067-help-me-please/#findComment-12250937
https://linustechtips.com/topic/1028067-help-me-please/#findComment-12250944
